Perform this procedure to save the current configuration on Fabric IPsec Gateway Virtual Machine (VM) to a specific file.
Saving configuration of Fabric IPsec Gateway VM to file "test":Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> save config file test
The following table defines parameters for the save config command.
| Variable | Value |
| file WORD <1-255> | Specifies the name of file to save the configuration of the Fabric IPsec Gateway VM. |
