Display the current device configuration.
Use the clear-stats command to clear EAP or NEAP statistics.
show eapol system
Product Notice: auto-isid-offset functionality is not available on VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
Switch:#enable Switch:1#show eapol system ================================================================================ Eapol System ================================================================================ eap : disabled Eapol Version : 3 non-eap-pwd-fmt : mac-addr non-eap-pwd-fmt key : ****** non-eap-pwd-fmt padding : disabled auto-isid-offset status : disabled auto-isid-offset value : 1000 --------------------------------------------------------------------------------
