Create and enable Endpoint Tracking on ports and MLT/SMLT interfaces. Creating, deleting, enabling, and disabling Endpoint Tracking on interfaces can be accomplished as separate steps using this procedure.
On the switch, add and configure the RADIUS server as configured in Extreme Management Center.
Configure ports and MLT/SMLT interfaces to function as Switched UNI interfaces, and then create and enable Endpoint Tracking on those interfaces.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface mlt <1-512>
flex-uni enable
Create Endpoint Tracking on the interface:
endpoint-tracking
Create and enable Endpoint Tracking on the interface:
endpoint-tracking enable
Configure Endpoint Tracking globally on the switch.
