Use the following procedure to display the IS-IS statistics and counters.
Switch:1# show isis statistics
ISIS System Stats
LEVEL CORR AUTH AREA MAX SEQ SEQ NUM OWN LSP BAD ID PART LSP DB
LSPs FAILS DROP EXCEEDED SKIPS PURGE LEN CHANGES OLOAD
Level-1 0 0 0 0 1 0 0 0 0
Switch:1# show isis int-counters
ISIS Interface Counters
IFIDX LEVEL AUTH ADJ INIT REJ ID LEN MAX AREA LAN DIS
FAILS CHANGES FAILS ADJ CHANGES
Mlt2 Level 1-2 0 1 0 0 0 0 0
Port1/21 Level 1-2 0 1 0 0 0 0 0
Switch:1# show isis int-l1-cntl-pkts
ISIS L1 Control Packet counters
IFIDX DIRECTION HELLO LSP CSNP PSNP
Mlt2 Transmitted 13346 231 2 229
Mlt2 Received 13329 230 1 230
Port1/21 Transmitted 13340 227 2 226
Port1/21 Received 13335 226 1 227
The following table defines parameters for the clear isis stats command.
Variable |
Value |
error-counters |
Clears IS-IS stats error-counters. |
packet-counters |
Clears IS-IS stats packet-counters. |
Job Aid
The following table describes the fields in the output for the show isis statistics command.
Parameter |
Description |
LEVEL |
Shows the level of the IS-IS interface. |
CORR LSPs |
Shows the number of corrupted LSPs detected. |
AUTH FAILS |
Shows the number of times authentication has failed on the global level. |
AREA DROP |
Shows the number of manual addresses dropped from the area. |
MAX SEQ EXCEEDED |
Shows the number of attempts to exceed the maximum sequence number. |
SEQ NUM SKIPS |
Shows the number of times the sequence number was skipped. |
OWN LSP PURGE |
Shows how many times the local LSP was purged. |
BAD ID LEN |
Shows the number of ID field length mismatches. |
PART CHANGES |
Shows the number of partition link changes. |
LSP DB OLOAD |
Show the number of times the switch was in the overload state. |
The following table describes the fields in the output for the show isis int-counters command.
Parameter |
Description |
IFIDX |
Shows the interface index for the Ethernet or MLT interface. |
LEVEL |
AUTH FAILS |
Shows the number of times authentication has failed per interface. |
ADJ CHANGES |
Shows the number of times the adjacencies have changed. |
INIT FAILS |
Shows the number of times the adjacency has failed to establish. |
REJ ADJ |
Shows the number of times the adjacency was rejected by another router. |
ID LEN |
Shows the ID field length mismatches. |
MAX AREA |
Shows the maximum area address mismatches. |
LAN DIS CHANGES |
Shows the number of times the DIS has changed. |
The following table describes the fields in the output for the show isis int-l1-cntl-pkts command.
Parameter |
Description |
IFIDX |
DIRECTION |
Shows the packet flow (Transmitted or Received). |
HELLO |
Shows the amount of interface-level Hello packets. |
LSP |
Shows the amount of LSP packets. |
CSNP |
Shows the amount of CSNPs. |
PSNP |
Shows the amount of PSNPs. |
