The following section shows the steps required to configure TACACS+ on the switch.
The example displays how to:
  • Configure a key to be used by the TACACS+ server and the switch. In the example, the key is configured to the word secret.
  • Configure an IP address for the TACACS+ server. In the example the IP address for the primary server is 192.0.2.8, which is accessible by the Management Router VRF.
  • Configure the TACACS+ server to authenticate CLI sessions.
  • Enable TACACS+.
Switch
TACACS CONFIGURATION
tacacs server  host 192.0.2.8 key ******
tacacs protocol enable
tacacs accounting enable cli
tacacs authorization enable
tacacs authorization level 6
Verify your configuration
The show tacacs output must show as global enable: true to confirm TACACS is enabled.
The output for the show tacacs command must display the IP addresses for the TACACS+ Identity Engines Ignition Server. The IP addresses must be accessible to the Management Router VRF on the switch.
If you want to use the TACACS+ server to authenticate sessions in CLI, the output must display as authentication enabled for: cli. If you want to authenticate EDM sessions, the output must display as authentication enabled for: web.
Ensure the other parameters match what you have configured.
Global Status:
   global enable : true
   authentication enabled for : cli
   accounting enabled for : cli
   authorization : enabled
   User privilege levels set for command authorization : rwa
Server:
	              create :
Prio      Status  Key         Port  IP address      Timeout Single Source          SourceEnabled
Primary   Conn    ******      49    192.0.2.8       10      false  0.0.0.0         false
