BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
Use this procedure to display information about BFD IPv6 neighbors.
The following example displays BFD session information for an IPv6 neighbor.
Switch:1>show ipv6 bfd neighbors
BFD Session - GlobalRouter
MY_DISC YOUR_DISC NEXT_HOP STATE MULTI MIN_TX MIN_RX ACT_TX DETECT_TIME REMOTE_STATE APP RUN
1 0 2001:DB8:0:0:25AB:0:0:1 Down 3 200 200 1000 0 Down O
1 out of 1 BFD session displayed
APP and RUN Legend:
B=BGP_IPv6, O=OSPFv3, S=IPv6 Static Route
The following table defines parameters for the show ipv6 bfd neighbors command.
Variable |
Value |
WORD<0-128> |
Specifies the next-hop IPv6 address in the format a:b:c:d:e:f:g:h. |
vrf WORD<1-16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0-512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
