Feature |
Product |
Release introduced |
For configuration details, see VOSS User Guide. |
Auto-Negotiation |
5520 Series |
VOSS 8.2.5 Switch models:
5520-VIM-4XE at 1 Gbps only and 5520-VIM-4YE at 25 Gbps only |
VSP 4450 Series |
VSP 4000 4.0 |
VSP 4900 Series |
VOSS 8.1 Switch models:
VIM5-4XE at 1 Gbps only and VIM5-4YE at 25 Gbps only |
VSP 7200 Series |
VOSS 4.2.1 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VSP 8200 4.0 |
VSP 8400 Series |
VOSS 4.2 |
VSP 8600 Series |
VSP 8600 4.5 |
XA1400 Series |
VOSS 8.0.50 |
The Auto-Negotiation feature enables the devices to switch between the various operational modes in an ordered fashion and enables you to select a specific operational mode. The Auto-Negotiation feature also provides a parallel detection (called autosensing) function to recognize compatible devices, even if they do not support Auto-Negotiation and helps the device sense the link speed only; not the duplex mode.
You can use the show interfaces gigabitEthernet l1-config command to see the Auto-Negotiation operational state on a port. The operational state uses the configuration and transceiver type present in the port. If you enable Auto-Negotiation for the port but the transceiver type does not support Auto-Negotiation, the operational state is disabled (false).
