Display configured RA Guard policy information.
Switch:1# show ipv6 fhs ra-guard policy
IPv6 Ra Guard Policy Info
MIN-HOP MAX-HOP MANAGED
POLICY-NAME RA-SRC-ADDR-LIST RA-MAC-ADDR-LIST RA-PREFIX-LIST LIMIT LIMIT CON-FLAG PREF
Ra_guard_pol1 None None acl1 0 0 None None
All 1 out of 1 Total Num of ra-guard policy entries displayed
The following table defines parameters for the show ipv6 fhs ra-guard policy command.
Variable |
Description |
WORD<1–64> |
Displays the RA Guard policy for the specified policy-name. By default, all the configured RA Guard policies are displayed. |
Job Aid
The following table shows the field descriptions for the show ipv6 fhs ra-guard policy command.
Field |
Description |
POL-NAME |
Indicates the RA Guard policy name. |
DEVICE-ROLE |
Indicates if the device role is router or host. |
IPv6–ACC-LIST |
Indicates the IPv6 access list against which the incoming RA packet's source IPv6 address has to be validated. |
MAC-ACC-LIST |
Indicates the MAC access list against which the incoming RA packet's source MAC address has to be validated. |
PREFIX-LIST |
Specifies the IPv6 prefix list against which advertised prefix information in incoming RA packets source need to be validated. |
MIN HOP-LIMIT |
Indicates the advertised hop count minimum limit. |
MAX HOP-LIMIT |
Indicates the advertised hop count maximum limit. |
MANAGED CONF-FLAG |
Indicates the managed address configuration flag status in the advertised RA packet. |
RTR-PREF |
Indicates the advertised default router preference value. |
