Use the show ip igmp mrdisc neighbors command to display information about the IGMP multicast router discovery neighbors. The syntax for this command is as follows.
show ip igmp mrdisc neighbors [vrf WORD <0-16>] [vrfids WORD <0-512>]
The following table shows the field descriptions for this command.
Field |
Description |
VLAN ID |
Indicates the VLAN ID. |
SRC_PORT |
Indicates the source port. |
IP Addr |
Indicates the IP address. |
Advert-int |
Indicates the advertisement interval in seconds. |
QUERY-int |
Indicates the query interval in seconds. |
Robust-val |
Indicates the tuning for the expected packet loss on a subnet. If you expect packet loss on a subnet, increase the robustness variable. |
