Use this procedure to display the I-SID-to-VLAN assignments advertised by an FA Client or an FA Proxy, to be supported on the FA Server. These assignments can be accepted or rejected by the FA Server. An assignment that is successfully accepted by the FA Server results in the creation of a Switched UNI I-SID on the interface.
Verify that IS-IS and SPBM are properly configured on the FA Server switch.
Verify SPBM configuration using the command show running-config module spbm.
Verify IS-IS configuration using one of the following commands:
show isis
show isis interface
show isis adjacency
show isis lsdb
The following example displays a sample output for the show fa assignment command.
The state of I-SID-to-VLAN assignments on a client or proxy device is pending until it is changed by the FA Server to active or reject.
Switch:>en
Switch:1#show fa assignment
Fabric Attach Assignment Map
Interface I-SID Vlan State Origin
1/1 2 2 active proxy
1/2 3 3 active proxy
1/2 4 4 active proxy
1/3 5 5 reject proxy
4 out of 4 Total Num of fabric attach assignment mappings displayed
Variable definitions
The following table defines parameters for the show fa assignment command.
Variable |
Value |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
