Use the following procedure to configure a Transparent Port UNI or Switched UNI by mapping an I-SID to a port or MLT and VLAN together.
If you are configuring a T-UNI to terminate on a port or MLT on a switch in a vIST switch cluster, you must also configure the T-UNI I-SID on the other switch of the vIST switch cluster. You must configure the T-UNI I-SID on both switches of a vIST pair. It is not necessary to assign an actual port or MLT to the T-UNI on the second switch.
You must first create a type of service instance identifier (I-SID) to create the different types of services available. After you create an I-SID you can add members (ports or MLTs) to the I-SID to create end-points for the service.
Service Field Descriptions
Use the data in the following table to use the Service tab.
Name |
Description |
ID |
Specifies a unique value to identify the service associated with this entry. |
Type |
Specifies the type of service associated with this entry. |
MacLimitEnable |
Indicates whether the MAC limit is enabled (true) or disabled (false). |
MaxMacLimit |
Indicates the maximum learned value of the MAC address for each service I-SID. |
Action |
Specifies I-SID related actions. |
OriginBitMap |
Specifies the origin of the I-SID. |
| VnId |
Identifies the VXLAN service associated with this I-SID. |
Name Note:
This field does not apply to all hardware platforms. |
Specifies the name of the I-SID. |
