Viewing tunnel interfaces
View tunnel interfaces to verify the current configuration and operational status of IPv6 tunnels.
Switch:1#show ipv6 tunnel detail
Tunnel Interface Information
ID LOCAL ADDRESS REMOTE ADDRESS OPER STATUS TYPE
2 211.1.55.2 44.1.55.1 active manual
1 211.1.55.2 44.1.55.43 active manual
210 211.1.60.2 47.1.60.1 active manual
3 out of 3 Total number of entries displayed.
Address Information
IPV6 ADDRESS/PREFIX LENGTH TYPE ORIGIN STATUS
43:210:0:0:0:0:0:2/64 UNICAST MANUAL PREFERRED
fe80:0:0:0:0:0:d301:3702/64 UNICAST LINKLAYER PREFERRED
44:211:0:0:0:0:0:2/64 UNICAST MANUAL PREFERRED
Variable definitions
Use the data in the following table to use the show ipv6 tunnel command.
Variable | Value |
<1–2000> | Shows information for a specific tunnel ID. |
detail | Shows detailed address information for the tunnel. |
local {A.B.C.D} | Shows information for a specific local address (the local endpoint of the tunnel). |
remote {A.B.C.D} | Shows information for a specific remote address (the remote endpoint of the tunnel). |
