View the learned multicast group addresses in the host cache.
Switch:1#show ipv6 mld-host-cache
MLD Cache Information
PORT/VID GRPADDRESS SELF
mgmt ff02::1:ff00:3 enabled
mgmt ff02::1:ff4c:9400 enabled
mgmt ff02::1 enabled
Job aid
The following table describes the fields in the output for the show ipv6 mld-host-cache command.
Parameter |
Description |
GRPADDRESS |
Shows the IP address of the multicast group. When combined with the group mask, it identifies the prefix that the local router uses to advertise itself as a C-RP router. |
SELF |
Indicates whether or not the group is locally registered into MLD Host Cache.
PORT/VID |
Shows the port or VLAN that learns the multicast group. |
