Use this procedure to view non-EAPoL client MAC information on a port.
Use the clear-stats command to clear EAP and NEAP statistics.
Not all fields are supported on all hardware platforms.
Switch:1(config)#show eapol multihost non-eap-mac status
Eap Oper Status
PORT MAC STATE VLAN PRI Flex-UNI I-SID NON-EAP VLAN:I-SID
NUM ID Enable SOURCE AUTH AUTH
1/10 00:00:00:00:00:0e authenticated 10 2 true autoconfig radius 0:1015
Total Number of EAP Sessions: 1
Switch(config-if)#show eapol multihost non-eap-mac status verbose
Non-Eap Oper Status Verbose
PORT MAC STATE VLAN PRI Flex-UNI I-SID NON-EAP VLAN:I-SID ACL ACEs
2/11 00:00:00:00:01:02 authenticated N/A 0 true radius radius 0:10555
Total Number of NEAP Sessions: 1
Use the data in the following table to use the show eapol multihost non-eap-mac status command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
<1-4059> |
verbose Note:
Exception: Not supported on VSP 4450 Series, XA1400 Series, or VSP 8600 Series |
Displays non-EAPoL client MAC information. |
Job Aid
The following table describes the output for the show eapol multihost non-eap-mac status command.
Parameter |
Description |
PORT NUM |
Displays the port number in use. |
MAC |
Displays the MAC address of the client. |
STATE |
Indicates the authentication status of the non EAP host that is authenticated using radius server. |
VLAN ID |
Indicates the VLAN assigned to the client. |
PRI Note:
Indicates port priority. |
Flex-UNI Enable Note:
Indicates Flex-UNI status. |
I-SID SOURCE Note:
Exception: Not supported on XA1400 Series or VSP 8600 Series |
Indicates the I-SID source. |
NON-EAP AUTH Note:
Exception: Not supported on XA1400 Seriesor VSP 8600 Series |
Indicates Non-EAP authorization source. |
VLAN:I-SID Note:
Indicates the VLAN to I-SID bindings. |
ACL Note:
Indicates the access-control list. Note:
This column is visible only when you use the optional verbose parameter in the command. |
ACEs Note:
Indicates the access-control entries. Note:
