View the storage usage for modules in the chassis.
You cannot perform this procedure on hardware platforms with fixed configurations. It is only available for platforms where you can install modules in slots.
- In the Device Physical View tab, select a module slot.
- Click Card.
- Click the Storage Usage tab.
Storage Usage Field Descriptions
Use the data in the following table to use the Storage Usage tab.
Name |
Description |
IntflashBytesUsed |
Specifies the number of bytes used in internal flash memory. |
IntflashBytesFree |
Specifies the number of bytes available for use in internal flash memory. |
IntflashNumFiles |
Specifies the number of files in internal flash memory. |
UsbBytesUsed |
Specifies the number of bytes used in USB device. |
UsbBytesFree |
Specifies the number of bytes available for use in USB device. |
UsbNumFiles |
Specifies the number of files in USB device. |
