This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this procedure to configure ports operating in Auto-sense mode to determine the Layer 3 QoS actions the switch performs. The Auto-sense access ports override the Differentiated Services Code Point (DSCP) markings.
Configure the Auto-sense access ports:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch(config)#auto-sense access-diffserv enable
The following table defines parameters for the auto-sense access-diffserv command.
| Variable | Value |
| enable |
Configures the ports operating in Auto-sense mode to determine the Layer 3 QoS actions the switch performs. The Auto-sense access ports override the Differentiated Services Code Point (DSCP) markings. The default configuration is enabled. |
