The DvR Controller and the DvR Leaf node have the following configuration limitations:
On a Controller, for any VLAN, you can either configure DvR or VRRP but not both. Similarly, you can either configure DvR or RSMLT but not both.
On a leaf node, you cannot configure the following:
Layer 3 (for example, IP interfaces, IP routing and VRFs). You can only perform Layer 2 configuration.
platform VLANs. You cannot configure a platform VLAN directly on a DvR leaf node. However, you can configure a VLAN Management Instance on a DvR leaf node. After you configure the management VLAN, you can configure a platform VLAN.
dynamic routing protocols like OSPF, RIP and BGP on a DVR enabled VLAN.
static routes such that the next-hop exists on any DVR enabled VLAN.
