Use this procedure to clear dynamic ARP table entries associated with the interface or VLAN.
Clear ARP entries:
Switch:1> enable Switch:1# clear ip arp interface gigabitethernet 1/16
Variable definitions
Use the data in the following table to use the clear ip arp interface command.
Variable |
Value |
<1-4059> |
gigabitethernet|vlan |
Specifies the interface type. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
