Use this procedure to view or configure FA I-SID-to-VLAN assignment information.
  1. In the navigation pane, expand Configuration > Edit.
  2. Click Fabric Attach.
  3. Click the Assignment tab.
  4. If you make configuration changes, click Apply to save changes.
Assignments Field Descriptions
Use the data in the following table to use the Assignments tab.
Name
Description
IfIndex
Specifies the interface identifier of the I-SID-to-VLAN assignment.
Isid
Specifies the I-SID value of the I-SID-to-VLAN assignment.
Vlan
Specifies the VLAN ID component of the I-SID-to-VLAN assignment.
State
Specifies the current state of the I-SID-to-VLAN assignment.
It can be one of the following values:
  • Other
  • Pending
  • Active
  • Rejected
Origin
Specifies the origin information of the I-SID-to-VLAN assignment.
