Use the show ip igmp ssm command to display the SSM group range and the status of dynamic learning. The syntax for this command is as follows.
show ip igmp ssm [vrf WORD <0-16>] [vrfids WORD <0-512>]
This command is not supported on a node configured as the DvR Leaf within a DvR domain.
The following table shows the field descriptions for this command.
Field |
Description |
DYNAMIC LEARNING |
Indicates whether dynamic learning is enabled at a global level. |
SSM GROUP RANGE |
Indicates the IP address range for the SSM group. |
