View port routing statistics to manage network performance.
This command is not available on all hardware platforms.
show routing statistics interface [gigabitethernet] [{slot/port[-slot/port][,...]}]
Switch:1#show routing statistics interface gigabitethernet 1/7-1/9
Port Stats Routing
PORT IN_FRAME IN_FRAME IN OUT_FRAME OUT_FRAME
NUM UNICAST MULTICAST DISCARD UNICAST MULTICAST
1/7 1386 0 0 1344 0
1/8 1302 0 0 1344 0
1/9 0 0 0 0 0
Use the data in the following table to use the show routing statistics interface command.
Variable |
Value |
gigabitethernet |
Specifies the interface type. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Job Aid
The following table describes the output for the show routing statistics interface command.
Parameter |
Description |
PORT NUM |
Indicates the port number. |
IN_FRAME UNICAST |
The count of inbound unicast frames. |
IN_FRAME MULTICAST |
The count of inbound multicast frames. |
IN DISCARD |
The count of inbound discarded frames. |
OUT_FRAME UNICAST |
The count of outbound unicast frames. |
OUT_FRAME MULTICAST |
The count of outbound multicast frames. |
