Use the following procedure to display the configured IKE profiles:
Switch:1#show ike profile
IKE Profile
Hash Encrypt Encrypt DH Exchange Lifetime
Name Algo Algo Key Len Group Mode seconds
DFLT_IKE_PROFILE sha256 aesCbc 256 modp2048 main 86400
ikePRO sha256 aesCbc 256 modp2048 main 180
test sha256 aesCbc 256 modp2048 main 86400
Variable Definition
The following table defines parameters for the show ike profile command.
Variable |
Value |
profile WORD<1–32> |
Specifies the name of the profile to be displayed. |
Job aid
The following table describes the fields in the output for the show ike profile command.
Parameter |
Description |
Name |
Specifies the name of the IKE Phase 1 profile. |
Hash Algo |
Specifies the hash authorization algorithm. The supported values are md5, sha, and sha256.
Encrypt Algo |
Specifies the crytographic algorithm. The supported values are desCbc, 3DesCbc, and aesCbc. |
Encrypt Key Len |
Specifies the length of the encryption key. The supported values are 128, 192 and 256. |
DH Group |
Specifies the Diffe-Hellman (DH) group. The supported values are modp768, modp1024, and modp2048. |
Exchange Mode |
Specifies the IKE mode. The supported mods are main mode and aggressive mode. |
Lifetime seconds |
Specifies the lifetime value in seconds. The value ranges from 0 to 4294967295 seconds. |
