Perform this procedure to configure the destination IP address for the IPsec tunnel on a specific IS-IS logical interface on the switch.
Product Notice: This procedure only applies to XA1400 Series switches.
Configuring destination IP address for IPsec tunnel.Switch:1>enable Switch:1#configure terminal Switch:1(config)#logical-intf isis 1 Switch:1(config-isis-1-192.0.2.25)ipsec tunnel-dest-ip 192.0.2.30
The following table defines the variable for ipsec tunnel-dest-ip command.
| Variable | Value |
| {A.B.C.D} | Specifies destination IP address for the IPsec tunnel on a specific IS-IS logical interface. |
