Use this procedure to view the port-based shaper information. The system displays the port, egress rate limit in Kbps, and the rate limit status.
enable
show qos shaper interface gigabitEthernet [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Switch:1# show qos shaper interface gigabitEthernet 1/1
Port Egress Rate-Limiting(Shape)
PORT EGRESS RATE-LIMIT(kbps) ENABLED/DISABLED
1/1 0 DISABLED
