Display information about classless interdomain routing (CIDR) routes.
The following table defines parameters for the show ip bgp cidr-only command.
Variable |
Value |
<prefix/len> |
Specifies an exact match of the prefix. This variable is an IP address and an integer value from 0–32 in the format a.b.c.d/xx. |
vrf WORD<1–16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
Job Aid
Use the data in the following table to understand the show ip bgp cidr-only command output.
Field |
Description |
NETWORK/MASK |
Specifies the network IP address and exact mask length (must be an integer value from 0–32). |
PEER REM ADDR |
Specifies the IP address of the remote peer. |
NEXTHOP ADDRESS |
Specifies the IP address of the next hop. |
ORG |
Specifies the source of a route:
LOC PREF |
Specifies the local preference. |
