Perform this procedure to view PoE Power Sourcing Entity (PSE) information for remote LLDP-MED on specific ports.
- Click Port MED.
- Click the Neighbor PoE PSE tab.
Neighbor PoE PSE Field Descriptions
Name |
Description |
TimeMark |
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Specifies the port on which the remote LLDP-MED information is received. |
Index |
Specifies the particular connection instance that is unique to the remote LLDP-MED. |
PSEPowerAvailable |
Specifies the power available from the PSE connected remotely to the specific port. |
PSEPowerSource |
Specifies the type of PSE Power Source for the remote LLDP-MED.
PSEPowerPriority |
Specifies the power priority associated with the PSE LLDP-MED, for more information, see RFC 3621.
