Use the show ip pim static-rp command to display the static RP table. The syntax for this command is as follows.
The following table shows the field descriptions for this command.
Field |
Description |
GRPADDR |
Indicates the IP address of the multicast group. When combined with the group mask, it identifies the prefix that the local router uses to advertise itself as a static RP. |
GRPMASK |
Indicates the address mask of the multicast group. When combined with the group address, it identifies the prefix that the local router uses to advertise itself as a static RP. |
RPADDR |
Indicates the IP address of the static RP. This address must be one of the local PIM-SM enabled interfaces. |
STATUS |
Indicates the status of static RP. |
Display the static RP table:
Pim Static RP Table - GlobalRouter
GRPADDR GRPMASK RPADDR STATUS
239.0.0.0 255.0.0.0 20.0.0.90 valid
