View DHCP Relay information to display the current configuration for the forwarding path and the interface configuration.
Not all parameters are available in non-default VRFs.
Variable definitions
Use the information in the following table to help you use the show ipv6 dhcp-relay command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
vlan<1-4059> |
vrf WORD<1–16> |
Specifies the VRF name. |
vrfids WORD<0–512> |
Specifies the VRF ID. |
