The Management Instance supports the following interface types:
Management Instance CLIP
You can assign a circuitless management IP (CLIP) address bound to a VRF.
The IP address is not bound to a physical network; it does not transmit nor receive IPv4 Address Resolution Protocol (ARP) or IPv6 Neighbor Discovery (ND) messages.
You do not need to configure a default or static route. This interface type uses all routing information learned by protocols attached to the VRF.
Packets can ingress on any port or VLAN in the VRF. You can configure accept policies to access the Management Instance CLIP from other VRF. Inter-VRF access is not permitted with traditional IP routing using OSPF, BGP, or RIP. Packets ingressing the switch from a VLAN belonging to a different VRF without a configured accept policy will not reach the Management Instance CLIP IP address.
You can use this interface type for CLIP management network routing in a Fabric network or Layer 3 routing network.
Management Instance OOB
You can assign a management IP address bound to the Out-of-Band (OOB) interface.
The Dynamic Host Configuration Protocol (DHCP) Client can request an IPv4 address for the Management Instance OOB interface.
You must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link networks.
You can use this interface type for OOB management network routing, as an alternative to in-band network routing management.
Management Instance VLAN
You can assign a Management Instance IP address to an inband VLAN.
The DHCP Client can request an IPv4 address for the Management Instance VLAN interface.
The interface resides on the physical VLAN segment, behaving as a host for sending and receiving IPv4 ARP and IPv6 ND messages.
You must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link (other subnets) networks.
No internal routing occurs between other non Management Instance VLANs. Packets must ingress on one of the ports in the VLAN.
You can use the Management Instance VLAN for management network routing, such as binding the Management Instance VLAN to an I-SID, which routes all management traffic to a single I-SID in a Fabric network. Also, other normal VLAN related operations such as VLAN port member changes are valid.
You can create only one of each interface type.
