Perform this procedure to view and edit RSMLT peer information.
- Select RSMLT.
- Select the Peer tab.
Peer field descriptions
Use the following table to use the Peer tab.
Name |
Description |
IfIndex |
IP interface identification. |
VlanId |
Specifies the VLAN ID of the chosen VLAN. |
IpAddr |
Specifies the IP address on the RSMLT VLAN. |
MacAddr |
Specifies the MAC address of the selected VLAN. |
Enable |
Displays the RSMLT operating status as enabled or disabled. |
OperStatus |
Displays the RSMLT operating status as either up or down. The default is down. |
HoldDownTimer |
Defines how long the recovering/restarting system remains in a non-Layer 3 forwarding mode for the peer router MAC address. The range of this value is from 0 to 3600 seconds. The default is 0. |
HoldUpTimer |
Defines how long the RSMLT system maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 0. |
HoldDownTimeRemaining |
Displays the time remaining of the HoldDownTimer. The default is 0. |
HoldUpTimeRemaining |
Displays the time remaining of the HoldUpTimer. The default is 0. |
SmltId |
Specifies the ID range for the Split MultiLink Trunk. A valid range is 1 to 32. |
VrfId |
Identifies the VRF. |
VrfName |
Indicates the VRF name. |
