Use the show ip mroute interface command to display information about the multicast routes on the switch for a specific interface. The syntax for this command is as follows.
show ip mroute interface gigabitethernet [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
show ip mroute interface [vrf WORD <1–16>][vrfids WORD <0–512>]
This command is not supported on a node configured as the DvR Leaf within a DvR domain.
The following table shows the field descriptions for this command if you do not use optional command parameters.
Field |
Description |
INTERFACE |
Indicates the interface. |
TTL |
Indicates the datagram TTL threshold for the interface. IP multicast datagrams with a TTL less than this threshold are not forwarded out of the interface. The default value of 0 means all multicast packets are forwarded out of the interface. |
PROTOCOL |
Indicates the routing protocol running on this interface. |
The following table shows the field descriptions for this command if you use optional command parameters.
Field |
Description |
PORT |
Shows the slot and port location. |
MROUTE STR LIMIT |
Indicates the maximum number of multicast streams that can enter the CPU through this port. |
MROUTE STR LIMIT TMR |
Indicates the sampling period (in seconds) to check number of multicast streams that enter the CPU through this port. |
ENABLE |
Indicates the status of the mroute stream limit on the port. |
