Use the following procedure to display the configured IKE policies.
Switch:1#show ike policy
IKE Policy
Policy Addr Profile
Name Type Local Address Remote Address Name
iketest3 IPv4 192.168.152.104 192.168.149.207 test
v1pol IPv4 192.168.152.104 192.168.152.152 ikepro
IKE Policy
Policy Profile Revocation-Check peer-identity
Name Version Auth-Method Pre-Shared Key Method name
iketest3 2 digital-cert ocsp
v1pol 1 digital-cert ocsp
IKE Policy
Policy DPD Admin Oper Use IKE
Name Timeout State State P2 PFS DH Grp DH Group IntfId
iketest3 300 enable up disable enable modp1024 3047
v1pol 300 enable up disable enable modp1024 3047
Variable Definition
The following table defines parameters for the show ike policy command.
Variable |
Value |
policy WORD<1–32> |
Specifies the name of the policy to be displayed. |
laddr WORD<1–256> |
Specifies the local IPv4 or IPv6 address. |
raddr WORD<1–256> |
Specifies the remote IPv4 or IPv6 address. |
Job aid
The following table describes the fields in the output for the show ike policy command.
Parameter |
Description |
Policy Name |
Specifies the name of the policy that is displayed. |
Addr Type |
Specifies whether the IP address is an IPv4 or IPv6 address. |
Local Address |
Remote Address |
Profile Name |
Specifies the name of the profile. |
Profile version |
Specifies the version of the profile, version 1 or version 2. |
Auth-Method |
Specifies the authentication method. The supported values are digital-certificate and pre-shared-key. |
Revocation-Check Method |
Specifies the revocation check method as OCSP, CRL or none. |
Peer-identity name |
Specifies peer identity name for IKE phase 1. |
Pre-Shared Key |
Specifies the pre-shared key value. |
DPD Timeout |
Specifies the Dead-peer detection timeout in seconds. The supported value ranges from 1 to 4294967295 seconds. |
Admin State |
Specifies whether the IKE admin state is enabled or disabled. |
Oper State |
Specifies whether the policy is operational or not. The values are up and down. |
P2 PFS |
Specifies whether Phase 2 perfect forward secrecy is enabled or not. |
Use IKE DH Grp |
Specifies whether IKE can use the DH group or not. The values are enable and disable. |
DH Group |
Specifies the type of DH group selected. The supported values are modp768, modp1024, and modp2048. |
IntfId |
Specifies the ID of the interface on which the policy is applied. |
