Show SLPP information for a port so that you can view the loop information for a port.
Switch# show slpp interface GigabitEthernet 1/7
Port Interface
PORT PKT-RX PKT-RX INCOMING SLPP PDU
NUM THRESHOLD VLAN ID ORIGINATOR
1/7 enabled 5
PORT PKT-RX TIME LEFT
NUM COUNT TO CLEAR RX COUNT
1/7 29 21600
Variable definitions
Use the data in the following table to use the show slpp interface GigabitEthernet command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
