Displaying foreign sources
Use the following procedure to display the Gateway foreign source database. Foreign sources are originally learned from MSDP or statically configured on the Controller.
- Click SPB-PIM-GW.
- Click the Gateway-Foreign-Source tab.
Gateway-Foreign-Source field descriptions
Use the data in the following table to use the Gateway-Foreign-Source tab.
Name |
Description |
SourceAddress |
Displays the foreign source IP address. |
GroupAddress |
Displays the multicast group IP address associated with the foreign source. |
ControllerSysId |
Displays the system ID of the controller node that sends this foreign source. |
ControllerHostName |
Displays the host name of the controller node that sends this foreign source. |
GatewaySysId |
Displays the system ID of the node selected as the gateway for this foreign source. |
GatewayHostName |
Displays the host name of the node selected as the gateway for this foreign source. |
InVid |
Displays the VLAN ID of the SPB-PIM Gateway interface through which the source of this source is reachable. |
InPort |
Displays the physical interface through which the source of this source is reachable. |
OwnerType |
Displays if the owner is MSDP or static. |
