Add a remote NTP server to the configuration by specifying its IP address. NTP adds this IP address to a list of servers, which the local NTP client uses to query remote time servers for time information. The list of qualified servers called to is a peer list.
For NTPv3, you can configure a maximum of 10 IPv4 NTP servers.
NTPv3 is only supported on VSP 8600 Series.
For NTPv4, this procedure adds the NTP server information to the switch that is acting as an NTP client. You can configure a maximum of 10 IPv4 NTP servers and 10 IPv6 NTP servers.
Switch:>enable Switch:1configure terminal Switch:1(config)#ntp server 192.0.2.187
The output for the show ntp server command includes different information for NTPv3 and NTPv4.
For NTPv3:
Switch:1(config)#show ntp server ========================================================================================== NTP Server ========================================================================================== Server Ip Enabled Auth Key Id Source IP Auth Type ------------------------------------------------------------------------------------------ 192.0.2.187 true false 0 0.0.0.0 N/A
For NTPv4:
Switch:1(config)#show ntp server ========================================================================================== NTP Server ========================================================================================== Server Ip Enabled Auth Key Id Auth Type ------------------------------------------------------------------------------------------ 192.0.2.187 true false 0 N/A
The following table defines parameters for the ntp server command.
Variable |
Value |
auth-enable |
Activates MD5 or SHA1 authentication on this NTP server. Without this option, the NTP server will not have any authentication by default. |
authentication-key <0-65534> |
Specifies the key ID value used to generate the MD5 or SHA1 digest for the NTP server. The default authentication key is 0, which indicates disabled authentication. |
enable |
Activates the NTP server. To set this option to the default value, use the default operator with the command. |
source-ip
WORD<0–46>
Note:
Exception: only supported on VSP 8600 Series. |
Specifies the source IP for the server. If you do not configure this parameter, by default, the source IP entry is initialized to 0.0.0.0. The IP address specified can be any local interface. The source-ip parameter applies only to NTPv3. |
WORD<0–255> |
Specifies the IPv4 or IPv6 address of the NTP server. |
