Perform this procedure to properly remove the IOC module that is in the master CP slot, when the system operates in HA mode.
enable
configure terminal
Important
Do not reinsert an IOC module until at least 15 seconds has elapsed, which is long enough for another CP slot to become master.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#sys action cpu-switch-over
