![Important](images/important.png)
Important
If you do not configure the thresholds, EDM displays only the ingress and egress records that are currently in use.
- In the navigation pane, expand the following folders: .
- Click IPv6 Mroute.
- Click the Resource Usage tab.
- Configure the ingress and egress thresholds.
- Configure the notification methods.
- Click Apply.
Resource Usage field descriptions
Use the data in the following table to use the Resource Usage tab.
Name |
Description |
Ingress Records In-Use |
Displays the number of ingress records (source or group) traversing the switch. |
Egress Records In-Use |
Displays the number of egress records traversing the switch. |
Ingress Threshold |
Configures the ingress threshold level (0–32767). |
Egress Threshold |
Configures the egress threshold level (0–32767). |
SendTrapAndLog |
Sends both trap and log notification messages after the number of streams exceeds a threshold level. |
SendTrapOnly |
Sends only trap notification messages after the number of streams exceeds a threshold level. You can configure only one notification type. |
LogMsgOnly |
Sends only log notification messages after the number of streams exceeds a threshold level. |
