This section provides CLI procedures for Unicast Reverse Path Forwarding configuration.
Enabling urpf-mode boot flag
To configure Unicast Reverse Path Forwarding on a port or VLAN, you are required to enable the urpf-mode boot flag. If you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
Use the following procedure to enable the urpf-mode boot flag. By default, urpf-mode is disabled.
Enable the urpf-mode boot flag:
Switch:1> enable Switch:1# configure terminal Switch:1(config)# boot config flags urpf-mode The new setting requires a reboot to take effect! The configuration will be saved and rebooted. Are you sure you want to re-boot the switch (y/n)? y
View the status of the urpf-boot flag:
Flag support can vary across hardware models.
Switch:1#show boot config flags flags advanced-feature-bandwidth-reservation low flags block-snmp false flags debug-config false flags debugmode false flags dvr-leaf-mode false flags enhancedsecure-mode false flags factorydefaults false flags flow-control-mode true flags ftpd true flags ha-cpu true flags hsecure false flags ipv6-egress-filter true flags ipv6-mode false flags linerate-directed-broadcast false flags logging true flags nni-mstp false flags reboot true flags rlogind false flags savetostandby true flags spanning-tree-mode mstp flags spbm-config-mode true flags sshd true flags syslog-rfc5424-format true flags telnetd true flags tftpd true flags trace-logging false flags urpf-mode true flags verify-config true flags vrf-scaling true flags vxlan-gw-full-interworking-mode false
Use the following procedure to view the status of the uRPF configuration on a port.
- You must enable the urpf-mode boot flag.
When you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
You must log on to the GigabitEthernet Interface Configuration mode in CLI.
You must configure unicast reverse path forwarding on a port.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface GigabitEthernet 1/10Verify the configuration on the port:
Switch:1(config-if)# show ip interface gigabitethernet
Brouter Port Ip
PORT VRF IP_ADDRESS NET_MASK BROADCAST REASM ADVERTISE DIRECT RPC RPCMODE
NUM NAME MAXSIZE WHEN_DOWN BCAST
1/1 Glob~ 192.0.2.3 255.255.255.0 ones 1500 disable disable disable exist-only
1/10 spbo~ 198.51.100.4 255.255.255.0 ones 1500 disable disable disable exist-only
PORT VRF
NUM NAME
1/1 GlobalRouter
1/10 spboip
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface GigabitEthernet 4/16Verify the configuration on the port:
Switch:1(config-if)#show ipv6 interface gigabitethernet
Port Ipv6 Interface
IFINDX BROUTER PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT MCAST IPSEC RPC RPCMODE
INDX ADDRESS STATE STATE LMT TIME TIME STATUS
192 4/16 e4:5d:52:3c:65:02 enable down ETHER 1500 2 30000 1000 disable disable disable existonly
Port Ipv6 Address
IPV6 ADDRESS BROUTER TYPE ORIGIN STATUS
2001:db8:0:0:0:0:0:ffff/64 4/16 UNICAST MANUAL INACCESSIBLE INF INF
2001:db8:0:0:e65d:52ff:fe3c:6502/64 4/16 UNICAST LINKLAYER INACCESSIBLE INF INF
1 out of 5 Total Num of Interface Entries displayed.
2 out of 10 Total Num of Address Entries displayed.
Use the following procedure to view the status of the uRPF configuration on a VLAN.
- You must log on to the VLAN Interface Configuration mode in CLI.
Important
You must assign a valid IP address to the selected port.
You must configure unicast reverse path forwarding on a VLAN.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface vlan 2Verify the configuration on the VLAN:
Switch:1(config-if)# show interfaces vlan ip
Vlan Ip
VLAN VRF IP NET BCASTADDR REASM ADVERTISE DIRECTED RPC RPCMODE RMON
ID NAME ADDRESS MASK FORMAT MAXSIZE WHEN_DOWN BROADCAST
1050 Globa~ 192.0.2.9 255.255.255.0 ones 1500 disable disable disable exist-only disable
1102 Globa~ 198.51.100.1 255.255.255.0 ones 1500 disable disable disable exist-only disable
1133 iir3 192.0.2.10 255.255.255.0 ones 1500 disable disable disable exist-only disable
1500 spboip 192.0.2.11 255.255.255.0 ones 1500 disable disable disable exist-only disable
1590 spboip 198.51.100.2 255.255.255.0 ones 1500 disable disable disable exist-only disable
4057 Globa~ 192.0.2.12 255.255.255.0 ones 1500 disable disable disable exist-only disable
All 16 out of 16 Total Num of Vlan Ip Entries displayed
VLAN VRF
ID NAME
1050 GlobalRouter
1102 GlobalRouter
1133 iir3
1500 spboip
1590 spboip
4057 GlobalRouter
Switch:1(config-if)# show ipv6 interface vlan
Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT MCAST IPSEC RPC RPCMODE
3170 1122 2c:f4:c5:dc:b4:89 enable up ETHER 1500 64 30000 1000 disable disable disable existonly
3174 1126 2c:f4:c5:dc:b4:8b enable up ETHER 1500 64 30000 1000 disable disable disable existonly
3185 1137 2c:f4:c5:dc:b4:90 enable up ETHER 1500 64 30000 1000 disable disable disable existonly
Vlan Ipv6 Address
IPV6 ADDRESS VLAN-ID TYPE ORIGIN STATUS
2001:db8:0:0:0:0:0:1 V-1122 UNICAST MANUAL PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b489 V-1122 UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1 V-1126 UNICAST MANUAL PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b48b V-1126 UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1 V-1137 UNICAST MANUAL PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b490 V-1137 UNICAST LINKLAYER PREFERRED
3 out of 4 Total Num of Interface Entries displayed.
6 out of 7 Total Num of Address Entries displayed.
