Use the following procedure to configure optional IS-IS global parameters.
Switch> enable
Switch# configure terminal
Switch(config)# router isis
Switch(config-isis)# csnp-interval 10
Switch(config-isis)# is-type l1
Switch(config-isis)# max-lsp-gen-interval 800
Switch(config-isis)# metric wide
Switch(config-isis)# overload
Switch(config-isis)# overload-on-startup 30
Switch(config-isis)# psnp-interval 10
Switch(config-isis)# retransmit-lsp-interval 10
Switch(config-isis)# default sys-name
Switch(config-isis)# spf-delay 200
Switch(config-isis)# default system-id
Variable definitions
The following table defines parameters for the csnp-interval command.
Variable |
Value |
<1–600> |
Specifies the CSNP interval in seconds. This is a system level parameter that applies for level 1 CSNP generation on all interfaces. A longer interval reduces overhead, while a shorter interval speeds up convergence. The default value is 10. Use the no or default options to set this parameter to the default value of 10. |
The following table defines parameters for the is-type command.
Variable |
Value |
{l1|l12} |
Sets the router type globally:
The default value is l1. Use the no or default options to set this parameter to the default value of l1. |
The following table defines parameters for the max-lsp-gen-interval command.
Variable |
Value |
<30–900> |
Specifies the maximum interval, in seconds, between generated LSPs by this Intermediate System. The default value is 900 seconds. Use the no or default options to set this parameter to the default value of 900. |
The following table defines parameters for the metric command.
Variable |
Value |
{narrow|wide} |
Specifies the IS-IS metric type. Only wide is supported. The default value is wide. Use the no or default options to set this parameter to the default value of wide. |
The following table defines parameters for the overload command.
Variable |
Value |
overload |
Sets or clears the overload condition. The default value is disabled. Use the no or default options to set this parameter to the default value of disabled. |
The following table defines parameters for the overload-on-startup command.
Variable |
Value |
<15–3600> |
Specifies the IS-IS overload-on-startup value in seconds. The overload-on-startup value is used as a timer to control when to send out LSPs with the overload bit cleared after IS-IS startup. The default value is 20. Use the no or default options to set this parameter to the default value of 20. |
The following table defines parameters for the psnp-interval command.
Variable |
Value |
<1–120> |
Specifies the PSNP interval in seconds. This is a system level parameter that applies for level 1 PSNP generation on all interfaces. A longer interval reduces overhead, while a shorter interval speeds up convergence. The default value is 2. Use the no or default options to set this parameter to the default value of 2. |
The following table defines parameters for the retransmit-lsp-interval command.
Variable |
Value |
<1–300> |
Specifies the minimum time between retransmission of an LSP. This defines how fast the switch resends the same LSP. This is a system level parameter that applies for Level1 retransmission of LSPs. The default value is 5 seconds. Use the no or default options to set this parameter to the default value of 5. |
The following table defines parameters for the spf-delay command.
Variable |
Value |
<0–5000> |
Configures the delay, in milliseconds, to pace successive Shortest Path First (SPF) runs. The timer prevents more than two SPF runs from being scheduled back-to-back. The mechanism for pacing SPF allows two back-to-back SPF runs. The default value is 100 milliseconds. Use the no or default options to set this parameter to the default value of 100 milliseconds. |
The following table defines parameters for the sys-name command.
Variable |
Value |
WORD<0–255> |
Specifies a name for the system. This may be used as the host name for dynamic host name exchange in accordance with RFC 2763. By default, the system name comes from the host name configured at the system level. Use the no or default options to set this parameter to the default value (host name). Note:
No consistency checks appear when you edit sys-name. |
The following table defines parameters for the system-id command.
Variable |
Value |
<xxxx.xxxx.xxxx> |
Specifies the IS-IS system ID for the switch. Use the no or default options to set this parameter to the default value (node BMAC). |
Job aid
Important
After you have configured the SPBM nickname and enabled IS-IS. To maintain the same nickname with a different system ID, perform the following steps:
Disable IS-IS.
Change the system ID.
Change the nickname to a temporary one.
Enable IS-IS.
Wait up to 20 minutes for the LSPs with the original system ID to age out.
To check the age out time, use the show isis lsdb sysid <original-sys-id> command on any of the other SPB nodes in the network. When there is no output from this command, proceed to the next step. The time left (in seconds) for the LSPs to age out is shown under the column LIFETIME.
Disable IS-IS.
Change the nickname to the original nickname.
Enable IS-IS.
