View fan information to monitor the alarm status of the cooling ports in the chassis.
This tab does not appear on the VSP 8600 Series switch.
For platforms that support both back-to-front and front-to-back airflow, the airflow direction must be the same for both the power supply fans and the chassis fan.
- On the Device Physical View, select the Device.
- Click Chassis.
- Click the Fan Info tab.
Fan Info field descriptions
Use the data in the following tables to use the Fan Info tab.
Name |
Description |
Description |
Specifies a description of the fan location. |
OperStatus |
Specifies the operation status of the fan. |
OperSpeed |
Specifies the actual fan speed. |
