Use the show ipv6 pim neighbor command to display information about the neighboring routers configured with IPv6 PIM-SM. The syntax for this command is as follows.
Switch:1(config)#show ipv6 pim neighbor
Pim Neighbor - GlobalRouter
INTERFACE ADDRESS UPTIME EXPIRE
Vlan2 fe80:0:0:0:12cd:aeff:fe69:f900 0 day(s), 00:08:33 0 day(s), 00:01:43
Vlan7 fe80:0:0:0:b647:5eff:fe3a:8582 0 day(s), 00:08:30 0 day(s), 00:01:18
Total PIM Neighbors Displayed: 2/2
The following table shows the field descriptions for this command.
Field |
Description |
INTERFACE |
Indicates the interface number. |
ADDRESS |
Indicates the IPv6 address of the PIM neighbor. |
UPTIME |
Indicates the elapsed time since this PIM neighbor last became a neighbor of the local router. |
EXPIRE |
Indicates the time that remains before this PIM neighbor times out. |
