  1. In the navigation pane, expand Configuration > Edit.
  2. Click Entity.
  3. Click the Child Index tab.
Child Index field descriptions
Use the following table to use the Child Index tab.
Name
Description
Index
Indicates the index of the entry.
ChildIndex
The index of the entry. The value of Physical Index for the contained physical entity.
