Use the following procedure to display the IS-IS interface parameters.
Switch:1# show isis interface
ISIS Interfaces
IFIDX TYPE LEVEL OP-STATE ADM-STATE ADJ UP-ADJ SPBM-L1-METRIC
Mlt2 pt-pt Level 1 UP UP 1 1 10
Port1/21 pt-pt Level 1 UP UP 1 1 10
Switch:1# show isis int-auth
ISIS Interface Auth
IFIDX AUTH-TYPE AUTH-KEYID AUTH-KEY
Mlt2 none 0
Port1/21 none 0
Switch:1# show isis int-timers
ISIS Interface Timers
IFIDX LEVEL HELLO HELLO HELLO
INTERVAL MULTIPLIER DR
Mlt2 Level 1 9 3 3
Port1/21 Level 1 9 3 3
Switch:1# show isis int-ckt-level
ISIS Circuit level parameters
IFIDX LEVEL DIS CKTID
Mlt2 Level 1 1
Port1/21 Level 1 2
Variable definitions
The following table defines parameters for the show isis interface command.
Variable |
Value |
[l1, l2, l12] |
Displays the interface information for the specified level: l1, l2, or l12. |
Job aid
The following sections describe the fields in the outputs for the IS-IS interface show commands.
show isis interface
The following table describes the fields in the output for the show isis interface command.
Parameter |
Description |
IFIDX |
Indicates the interface index for the Ethernet or MLT interface. |
TYPE |
Indicates the type of interface configured (only pt-pt is supported). |
LEVEL |
Indicates the level of the IS-IS interface (Level 1 [default] or Level 2). |
OP-STATE |
Shows the physical connection state of the interface. |
ADM-STATE |
Shows the configured state of the interface. |
ADJ |
Shows how many adjacencies are learned through the interface. |
UP-ADJ |
Shows how many adjacencies are active through the interface. |
SPBM-L1–METRIC |
Indicates the SPBM instance Level 1 metric on the IS-IS interface. |
show isis int-auth
The following table describes the fields in the output for the show isis int-auth command.
Parameter |
Description |
IFIDX |
Shows the interface index for the Ethernet or MLT interface. |
AUTH-TYPE |
Shows the type of authentication configured for the interface. Types include:
AUTH-KEYID |
Shows the authentication password configured for the interface. If the KeyId is not configured, the value is 0. |
AUTH-KEY |
Shows the HMAC-MD5 key needed for encryption. This is used only for HMAC-MD5. |
The following table describes the fields in the output for the show isis int-timers command.
Parameter |
Description |
IFIDX |
LEVEL |
Indicates the IS-IS interface level. |
HELLO INTERVAL |
Indicates the interval at which a Hello packet is sent to the IS-IS network. |
HELLO MULTIPLIER |
Indicates the multiplier that is used in conjunction with the Hello Interval. |
HELLO DR |
Indicates the interval at which a Hello packet is sent to the IS-IS network if the router is a designated router (DIS). |
The following table describes the fields in the output for the show isis int-ckt-level command.
Parameter |
Description |
IFIDX |
Shows the interface index for the ethernet or MLT interface. |
LEVEL |
Shows the level of the IS-IS interface (Level 1 [default] or Level 2). |
DIS |
Shows the Designated Intermediate System (DIS) of the circuit. |
CKT ID |
Displays the CKT ID. |
