Feature |
Product |
Release introduced |
For configuration details, see VOSS User Guide. |
ExtremeCloud IQ Agent |
5520 Series |
VOSS 8.2.5 |
VSP 4450 Series |
Not supported |
VSP 4900 Series |
VOSS 8.2 VSP4900-48P only VIMs: VIM5-4YE, VIM5-4X, VIM5-4XE, and VIM5-2Y only |
VSP 7200 Series |
Not supported |
VSP 7400 Series |
VOSS 8.2 |
VSP 8200 Series |
Not supported |
VSP 8400 Series |
Not supported |
VSP 8600 Series |
Not supported |
XA1400 Series |
VOSS 8.2 |
For the most current information on switches supported by ExtremeCloud™ IQ, see ExtremeCloud™ IQ Learning What‘s New.
ExtremeCloud IQ provides cloud-managed networking, and delivers unified, full-stack management of wireless access points, switches, and routers. It enables onboarding, configuration, monitoring, troubleshooting, reporting, and more. Using innovative machine learning and artificial intelligence technologies, ExtremeCloud IQ analyzes and interprets millions of network and user data points, from the network edge to the data center, to power actionable business and IT insights, and to deliver new levels of network automation and intelligence.
VOSS supports a zero touch connection to ExtremeCloud IQ. Zero touch deployment is used to deploy and configure a switch using ExtremeCloud IQ.
VOSS integrates with ExtremeCloud IQ using ExtremeCloud IQ Agent. When you enable IQAgent, you can configure and monitor VOSS devices using ExtremeCloud IQ.
ExtremeCloud IQ supports the following features for VOSS:
Firmware upgrade
IQAgent upgrade
Supplemental CLI
You can configure the following features using the ExtremeCloud IQ interface:
Hostname configuration
SNMP location
Device-level MTU
Flow control
Port state, usage type, and settings
VLAN configuration
DNS, NTP, SNMP, and Syslog servers
For more information about ExtremeCloud IQ, see https://www.extremenetworks.com/support/documentation/extremecloud-iq/.
