Configuring the date
Configure the calendar time in the form of month, day, year, hour, minute, and second.
Configure the date and time, and then verify the configuration.
Switch:1>enable Switch:1#clock set 19042014063030 Switch:1#show clock Wed Mar 19 06:30:32 2014 EDT
Variable definitions
Use the data in the following table to use the clock set command.
Variable |
Value |
MMddyyyyhhmmss |
Specifies the date and time in the format month, day, year, hour, minute, and second. |
