Use this task to add an IPv4 or IPv6 address to a Management Instance.
Ensure the IP address you plan to assign is not in use by an existing VLAN or CLIP IP subnet configured on the switch.
enable
configure terminal
mgmt {clip | oob | vlan}
ip address {A.B.C.D [A.B.C.D] | A.B.C.D/X}
ipv6 address WORD<0–255>
Add an IPv4 address to the VLAN Management Instance:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt vlan Switch:1(mgmt:vlan)#ip address 192.0.2.12/24
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt oob Switch:1(mgmt:oob)#ip address 192.0.2.12 255.255.255.0
Add an IPv6 address to the CLIP Management Instance:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt clip Switch:1(mgmt:clip)#ipv6 address 2001:DB8::1/128
