Use this task to display ExtremeCloud IQ Agent configuration information and status.
Display IQ Agent configuration information and status when IQ Agent is enabled using the default ExtremeCloud IQ server:
Switch:1>show application iqagent
IQAgent Info
Agent Admin State : true
Agent Version : 0.2.7
Agent Oper State : connected
Server Address : hac.extremecloudiq.com
Server Address Origin : None
Proxy Address : extremeiq.com
Proxy TCP Port : 21
Proxy Username : admin
Display IQ Agent disabled state:
IQAgent Info
Agent Admin State : false
Agent Oper State : disconnected
Server Address : 0.0.0.0
Proxy Address : 0.0.0.0
Proxy TCP Port : 0
Proxy Username :
Display IQ Agent configuration information and status when DHCP provides a dynamic server IP address:
IQAgent Info
Server Address : 192.0.2.1
Server Address Origin : DHCP
Proxy TCP Port : 0
Proxy Username :
Display IQ Agent configuration information and status when DHCP Client is disabled on the switch:
IQAgent Info
Proxy TCP Port : 0
Proxy Username :
Job Aid
The following sections describe the fields in the output for the show application iqagent command.
Output |
Description |
Agent Admin State |
Specifies the administrative state of the IQ Agent. |
Agent Version |
Specifies the IQ Agent version that runs on the device. |
Agent Oper State |
Specifies the operational status of the IQ Agent, whether IQ Agent is connected to ExtremeCloud IQ. |
Server Address |
Specifies the default ExtremeCloud IQ server. |
Server Address Origin |
Specifies the origin of the server IP address.
Proxy Address |
Specifies the proxy address. |
Proxy TCP Port |
Specifies the proxy TCP port. |
Proxy Username |
Specifies the proxy server username. |
Proxy Password |
Specifies the proxy server password. |
