This section provides procedures to configure and manage ZTP+ using the Command Line Interface (CLI).
After your VOSS device is onboarded, you have access to Extreme Management Center.
You must configure a Segmented Management Instance to use ZTP+. For more information, see Segmented Management Instance Configuration using the CLI.
For information about onboarding switches, see https://www.extremenetworks.com/support.
