Each PoE port has a configurable power limit. This configuration attribute limits the amount of power supplied on a particular port and varies across different hardware platforms. If a PD requires more than the configured limit, the device will not connect properly or is forced to run at a lower limit.
Platform |
Power Limit |
5520 Series |
98 watts |
VSP 4450 Series |
32 watts |
VSP4900-48P |
32 watts |
VSP4900-12MXU-12XE |
64 watts |
