Associate a port to a Virtual Router Forwarding (VRF) instance so that the port becomes a member of the VRF instance.
The VRF instance must exist. For more information about the creation of VRFs, see Create a VRF Instance.
You can assign a VRF instance to a port after you configure the VRF. The system assigns ports to the Global Router, VRF 0, by default.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface vlan <1–4059>
vrf <WORD 1-16>
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface gigabitethernet 1/12
Switch:1(config-if)# vrf red
